Replacing pinned data with other executions does not work
I’m on self hosted n8n, and I’m facing a really annoying issue. Basically, when I have pinned webhook data, and I choose a different execution to pin the data on, If you go into the node, you can see that the new pin data is there. However, I click execute and it chooses the old data. A really annoying bug, and I was wondering if someone could look at itWhat is the error message (if any)?
Hi
If you do not want to use the pinned data, just unpin it. This way, you will always work with new data
I know this used n8n for well over a year however the best happens when switching pinned data
Hi @Oscar_Growns, welcome!
Maybe re-reading the node would bring some help, also make sure to do a hard reload Ctrl+ Shift+r after switching pinned data in nodes, as sometimes the cached data might get into the flow
Welcome to the community!
This is actually a known quirk with how n8n handles pinned data in the browser. The hard reload trick mentioned above (Ctrl+Shift+R) is usually the fix.
A couple more things to try:
  1. After switching the pinned execution, close the node panel entirely, then reopen it before running
  2. If you’re on a self-hosted instance, check your n8n version - some older versions had a bug where the pin wouldn’t update properly until page refresh
  3. Try unpinning, saving the workflow, then re-pinning from the new execution
The pin data is stored in the workflow JSON, so if you open your workflow in JSON view (three dots > Download) you can see the actual pinned data and confirm whether it updated correctly. That helps narrow down if it’s a display issue vs actual data issue.
Hope that helps!
