My webhook is not receiving anything from instantly
I have a couple of campaigns running, hereby I use webhooks on the side of instantly with the settings to generate events in case any emails are sent or opened. however the connection between instantly using webhooks in n8n dont seem to connect, i have tried many different things to trouble shoot but to no prevail.
for instance I have confirmed with postman that the node is live.
Does anyone have experiance working with instantly and know how there messages look like?
Thanks
  • **Running n8n via cloud
Hi @Liepiecie,
It sounds like if Postman is working the issue might be with Instantly and their team may know what is going on or might be able to give you a sample of the data they are sending or check some logs.
Hi @Jon,
I managed, Thanks!
